American Radio Relay League (ARRL) Awards Grant to ORI
Good news!
American Radio Relay League (ARRL) has Generously Awarded a $3,000 Grant to Support the Open Research Institute (ORI) Amateur Radio Satellite Service Research and Development Program
ORI, a 501(c)(3) dedicated to open source research and development in amateur radio, has been awarded a $3,000 grant from the ARRL Foundation. This grant, the maximum amount, will be immediately applied to Phase 1 of the Digital Multiplex Transponder research and development program. This grant allows hardware prototypes for broadband microwave digital payloads to proceed much more quickly. All work completed by ORI is made available to the general public at no cost.
A project that will directly and immediately benefit from this work is the Amateur Radio Exploration (AREx) project, brought to you by Amateur Radio on the International Space Station (ARISS). ARISS is a project sponsored by the Amateur Radio Satellite Corporation (AMSAT).
AREx is devoted to designing and building amateur radio equipment for the Lunar Orbiting Platform Gateway project. This lunar orbiting station will have open source broadband microwave amateur equipment and affordable open source ground stations. AREx is not limited to Gateway, as there are many other opportunities under consideration that can re-use what is designed and built.
Documentation about the transponder program that this award supports can be found on the ORI website at the following links.
Overview:
https://openresearch.institute/2019/09/27/open-research-institute-phase-4-space-grant-application-overview/
Technical proposal:
https://openresearch.institute/2020/01/10/p4xt-digital-multiplexing-transponder-project-program-proposal/
Phase 1 statement of work can be found at the summary document linked below.
Summary:
https://openresearch.institute/2020/02/21/summary-proposal-open-research-institute-phase-1-p4xt/
Established in 1973 by the American Radio Relay League, Inc. (ARRL) as an independent and separate 501(c)(3) organization, the ARRL Foundation administers programs to support the Amateur Radio community.
Funded entirely by the generous contributions of radio amateurs and friends, ARRL Foundation administers programs for Amateur Radio award scholarships for higher education, award grants for Amateur Radio projects, and award special Amateur Radio program grants for The Victor C. Clark Youth Incentive Program and The Jesse A. Bieberman Meritorious Membership Program.
Find out more about the ARRL Foundation here: http://www.arrl.org/the-arrl-foundation
Here are some of the organizations that will appreciate your time, energy, effort, and enthusiasm.
ARISS is the home for AREx. ARISS can be found on the web at
https://www.ariss.org/
AMSAT North American is the home for ARISS. AMSAT is active in AREx in multiple roles and can be found on the web at
https://amsat.org
JAMSAT supports AREx and has partnered with ORI to work on the Gateway Ground Station. JAMSAT can be found on the web at
https://www.jamsat.or.jp
Open Research Institute supports AREx and open source amateur radio research & development, primarily microwave.
Find ORI on the web at
